DCC-GARCH-in-mean
mammus
DCC-GARCH-in-mean
Postby mammus » Tue Feb 28, 2012 9:54 am
I am trying to program the estimation of a GARCH-in-mean model with DCC. The code I have is for a bivariate (asymmetric) GARCH with DCC and I do not know how to program the feedback into the mean equation. Any help would be greatly appreciated.
' ORIGINAL 'H = (Dt)*(Rt)*(Dt) 'Rt = inverse(diag[Qt])*Qt*inverse(diag[Qt]) 'Qt = (Qbar - alpha*Qbar - beta*Qbar) + alpha*(en*en') + beta*Qt 'This is a DCC with 2 series, a DCC(1,1) Model ' [0] Load workfile and measure length of series load g:\siri\dcc.wf1 series obscount = 1 scalar obslength = @sum(obscount) ' [1] SPECIFY THE ASSET RETURN SERIES 'For two return series series y1 = ret_totmt series y2 = ret_5x ' [2] SPECIFY THE NUMBER OF ITERATIONS IN THE MLE, Engle and Sheppard (2001) used just one iteration !itermle = 100 ' [3] SPECIFY THE INITIAL VALUES OF THE PARAMETERS 'Coefficient vectors coef(1) alpha coef(1) beta 'VARY these depending on which will result in the highest likelihood value alpha(1) = 0.011390 beta(1) = 0.982627 'Setting the sample sample s0 @first+1 @last sample s1 @first+2 @last sample sf @first+3 @last sample sf_alt @first+13 @last 'sample s0 @first+561 @last-590 'sample s1 @first+562 @last-590 'sample sf @first+563 @last-590 'sample sf_alt @first+573 @last-590 'Initialization at sample s0 smpl s0 'Each return series is modeled with their respective mean equations and GARCH specifications: 'Use Bollerslev-Wooldridge QML 'standard errors equation eq1.arch(egarch,m=100,c=1e-5,h) y1 c res_b11_100 @ res_b11_100 equation eq2.arch(thrsh=1,m=100,c=1e-5,h) y2 c y2(-1) res_s_1000 @ res_s_1000 'Make residual series eq1.makeresids e1 eq2.makeresids e2 'Make a garch series from the univariate estimates 'p.202, p.336 in Command Reference eq1.makegarch h11 eq2.makegarch h22 'Normalized the resid e, e* -> en, wrt to h^0.5 series e1n = e1/h11^0.5 series e2n = e2/h22^0.5 'The Q_bar=E[en*en'] components and its sample equivalent series qbar11 = @mean(e1n*e1n) series qbar12 = @mean(e1n*e2n) series qbar21 = @mean(e2n*e1n) series qbar22 = @mean(e2n*e2n) 'The (en*en') matrix components series e11n = e1n*e1n series e12n = e1n*e2n series e21n = e2n*e1n series e22n = e2n*e2n 'Initialize the elements of Qt for variance targeting series q11 = @var(e1) series q12 = @cov(e1,e2) series q21 = @cov(e2,e1) series q22 = @var(e2) '**************************************************** 'Declare a loglikelihood object logl dcc dcc.append @logl logl 'The elements of matrix Qt dcc.append q11 = qbar11 - alpha(1)*qbar11 - beta(1)*qbar11 + alpha(1)*e11n(-1) + beta(1)*q11(-1) dcc.append q12 = qbar12 - alpha(1)*qbar12 - beta(1)*qbar12 + alpha(1)*e12n(-1) + beta(1)*q12(-1) dcc.append q21 = qbar21 - alpha(1)*qbar21 - beta(1)*qbar21 + alpha(1)*e21n(-1) + beta(1)*q21(-1) dcc.append q22 = qbar22 - alpha(1)*qbar22 - beta(1)*qbar22 + alpha(1)*e22n(-1) + beta(1)*q22(-1) 'As input to detQQQ dcc.append q12n = (qbar12 - alpha(1)*qbar12 - beta(1)*qbar12 + alpha(1)*e12n(-1) + beta(1)*q12(-1))/((abs(q11)^0.5)*(abs(q22)^0.5)) dcc.append q21n = (qbar21 - alpha(1)*qbar21 - beta(1)*qbar21 + alpha(1)*e21n(-1) + beta(1)*q21(-1))/((abs(q22)^0.5)*(abs(q11)^0.5)) 'Setting up the loglikelihood function, assuming that resid ~ N(0,H) 'The loglikelihood function is L' = -0.5*{summation from t=1 to T of ([log of determinant of inverse(diag[Qt])*Qt*inverse(diag[Qt])] + [en'*inverse(diag[Qt])*Qt*inverse(diag[Qt])*en]) 'So the determinant of inverse(diag[Qt])*Qt*inverse(diag[Qt]) dcc.append detQQQ = 1 - q12n*q21n 'Taking the adjoint{inverse(diag[Qt])*Qt*inverse(diag[Qt])} dcc.append cofact11 = 1*1 dcc.append cofact12 =(-1)*q21n dcc.append cofact21 =(-1)*q12n dcc.append cofact22 = 1*1 'Taking the inverse{inverse(diag[Qt])*Qt*inverse(diag[Qt])} dcc.append invQQQ11 = cofact11/detQQQ dcc.append invQQQ12 = cofact12/detQQQ dcc.append invQQQ21 = cofact21/detQQQ dcc.append invQQQ22 = cofact22/detQQQ 'Taking the en'*inverse{inverse(diag[Qt])*Qt*inverse(diag[Qt])}*en dcc.append enQQQen11 = e1n*invQQQ11*e1n dcc.append enQQQen12 = e1n*invQQQ12*e2n dcc.append enQQQen21 = e2n*invQQQ21*e1n dcc.append enQQQen22 = e2n*invQQQ22*e2n 'Append the loglikelihood function 'Instead of log(detQQQ) use log(abs(detQQQ)) dcc.append logl = -0.5*(log(abs(detQQQ)) + (enQQQen11+enQQQen21+ enQQQen12+enQQQen22)) 'Specifies the sample data where the estimation will be made smpl s1 'Estimates the parameters now using BHHH algorithm dcc.ml(b, showopts, m=!itermle, c=1e-5) 'A detQQQnpd = 0 indicates detQQQ is positive definite series count = (detQQQ<=0) scalar detQQQnpd = @sum(count) 'Display the estimated parameters show dcc.output 'Forecast the q's by initializing them series q11f = 0 series q12f = 0 series q21f = 0 series q22f = 0 'Specify the sample period to be forecasted smpl sf series q11f = qbar11 - alpha(1)*qbar11 - beta(1)*qbar11 + alpha(1)*e11n(-1) + beta(1)*q11(-1) series q12f = qbar12 - alpha(1)*qbar12 - beta(1)*qbar12 + alpha(1)*e12n(-1) + beta(1)*q12(-1) series q21f = qbar21 - alpha(1)*qbar21 - beta(1)*qbar21 + alpha(1)*e21n(-1) + beta(1)*q21(-1) series q22f = qbar22 - alpha(1)*qbar22 - beta(1)*qbar22 + alpha(1)*e22n(-1) + beta(1)*q22(-1) 'To plot the time-varying conditional correlation smpl sf_alt series rt = q12f/(@sqr(q11f)*@sqr(q22f)) graph rtgraph.line rt show rtgraph delete e1n e2n delete q12n q21n delete e11n e12n e21n e22n delete qbar* delete xbar* delete cofact* delete enqqqen* delete invqqq* delete enqqqen* delete eigenvect* delete invqqq* show detqqqnpd series eigmins scalar eigmin for !j = 4 to obslength 'Input the hijsim to the elements of a 2x2 Q matrix sym(2) Q Q(1,1) = q11f(!j) Q(2,1) = q21f(!j) Q(2,2) = q22f(!j) 'Take the eigenvalues of Q vector(4) Qeigenval Qeigenval = @eigenvalues(Q) 'Collect the min eigenvalues in each Qt eigmins(!j) = @min(Qeigenval) next eigmin = @min(eigmins) show eigmin
