Dynamic ols
luanvan10diem
Dynamic ols
Postby luanvan10diem » Mon Feb 06, 2012 7:28 am
I'm using eviews 7, i want use the dynamic ols (DOLS) procedure to run equation such as: Y(t) = aX(t) + b(k)d_X(t-k) + c(t) ;( with k=-i,i ) (eq1). When i use DOLS procedure, i only have a question: Y(t) = aX(t) + c(t) + d @trend (eq2). Please give me a procedures to run a results as (eq1).
Thanks you advances.
Re: Dynamic ols
Postby EViews Glenn » Mon Feb 06, 2012 1:00 pm
You're going to have to be a bit clearer about what you are doing.
luanvan10diem
Re: Dynamic ols
Postby luanvan10diem » Wed Feb 08, 2012 8:08 am
I want to use eviews 7 to run The Dynamic ols model (Stock and Watson,1993) such as: Yt = A(0) + A(i)Xt + B(j)d_X(t-j) + et, with j=(-p,p) (eq1). Although I have to follow the instructions in this guide, the result is not the same as the above equation. My result such as: Yt = A(0) + A(i)Xt + C@trend. Please give me how can run the DOLS in eview 7 to have result as (eq1).
Thanks in advance.
Re: Dynamic ols
Postby EViews Glenn » Wed Feb 08, 2012 11:01 am
If I understand correctly, just specify the Y and X and choose the DOLS option in the cointreg, indicate that you want only a constant in the cointegrating regression, and specify the lead and lags that you want to add for the difference terms.
