..more specifically..
I am trying to locate a generic Eviews program file (.PRG) that broadly replicates the Coincident Indicator work of Stock and Watson
ie estimating the unobserved component (Coincident index) from x observable (quarterly) macroeconomic variables using Kalman Filter/State Space (linear) model.
“A Dynamic Factor Model of Four Coincident Economic Indicators: An Experimental Coincident Index: Based on Stock and Watson (1991)”
.PRG for Kalman Filter
Abraham Vela
Re: .PRG for Kalman Filter
I guess you do not need a PRG file to do this. Actually, you shall be able to do it in a spreadsheet such as Excel!
For your benefit, Eviews has built-in state-spece specifications for kalman Filtering. Therefore, it must be straightforward to replicate the paper by Stock and Watson.
May be what you need is to figure out the appropiate state-space representation for an unobserved components model of the kind presented in the paper of your interest. I suggest you review thw Kalman filter chapter on "Applied Econometric Techniques by Mark P. Taylor , Keith Cuthbertson, Stephen G. Hall Hardcover, Univ of Michigan Pr, ISBN 0472103288". They cover the state-space for the unobserved component model.
I hope this is useful.
Regards,
Abe
Regards,
Abe
