Help needed urgently on very simple question (I hope!)
stats321
Postby stats321 » Mon Jan 16, 2012 12:15 pm
Hi everyone,
I am regressing panel data, and I keep getting the error message near singular matrix when I change the Period function to fixed and I get the error message 'positive or non-negative argument to function estimate expected of RE innovation variance' when I change it to random.
Can someone please explain what this means in laymans terms and how I can hope to correct it?
I've removed variables to deal with collinearity, but no matter how many i remove, I still get these error signs.
PLEASEPLEASE help me!! I'm stuck and am losing hope as I am not really sure what I am doing
Re: Help needed urgently on very simple question (I hope!)
Postby EViews Gareth » Mon Jan 16, 2012 12:22 pm
Could you post your workfile, and tell us the exact specification you're using?
stats321
Postby stats321 » Mon Jan 16, 2012 12:31 pm
I am trying to regress log(gdp) on log(airtransport) log(container port) log(electricity power loss) log(ICT imports) log(infant mortality) log(improved water source) log(raillines) (log road network) log(school enrolment) and Log(mortaility rates).
I have 57 cross sections spanning 1990-2009
I recognise that there are lots of variables and so I cut them, but regardless of which ones I cut out, or even if I just estimate using one dependent variable, it still gives me those error messages.
Am I missing something?
forum.xlsx
(139.46 KiB) Downloaded 288 times
Postby startz » Mon Jan 16, 2012 12:33 pm
It would be much easier to track down what you've done if you posted and EViews workfile, including the equation you are trying to estimate.
stats321
Postby stats321 » Mon Jan 16, 2012 12:38 pm
Sorry I am new to this.
In an ideal world, I would like to estimate:
log(gdp)= log(elecloss) log(airfreight) log(ictimport) log(infmort) log(mobile) log(port) log(railtot) log(roadtot) log(secondsch) log(water)
In panel options, it's not letting me change for fixed/random effect for the period.
I have never worked with panel data before so I could be missing something glaringly obvious and stupid!
log3.wf1
(138.68 KiB) Downloaded 219 times
Postby EViews Gareth » Mon Jan 16, 2012 12:43 pm
Your dependent variable (GDP) has no cross-section variance. i.e. it is the same for all cross-sections. You can't use the panel options if that's the case.
stats321
Postby stats321 » Mon Jan 16, 2012 12:46 pm
In what sense is it the same as I have (hopefully) got a different GDP value for each corresponding year for each country?
Postby startz » Mon Jan 16, 2012 12:47 pm
Your values for electric power are the same for every country, at least for 1990 and 1991. Therefore you can't estimate a period fixed effect.
Most likely, you have a data error.
stats321
Postby stats321 » Mon Jan 16, 2012 12:48 pm
Sorry for being such a novice at these things! I am trying to teach myself and it is not going so well.
Postby EViews Gareth » Mon Jan 16, 2012 12:54 pm
Take a look at the values for GDP in 1990 for cross-section 1. It is identical for GDP in 1990 for cross-section 2, and cross-section 3 etc....
As Startz pointed out, you have data errors.
stats321
Postby stats321 » Mon Jan 16, 2012 1:13 pm
I think that is working now- I knew it was something stupid on my part.
Thank you so much for your help I really appreciate it and I am sorry if I bother you with more silly questions!
