sample program of logl
cwlow48
Postby cwlow48 » Tue Dec 27, 2011 9:17 am
Attached are the sample program of logl which derived from EVIEWS. I slightly modified the program and plugged in my data.
In brief, i used the daily stock indices from 8 countries to calculate the price and volatility spillover.
In EGARCH, it ran pretty well. Problems began to arise in ML.
The error message shows there are missing values in @LOGL series at current coeeficient at observation 47 in "DO_LL1.ML(SHOWOPTS,M=1000,C=1E-5)"
Out of the 8 countries, i managed to run 2 of them in ML. I have tried to alter the initial value but still encountered the similar problem.
Could any one pose a comment on this? Thanks in advance.
PS: attached program do not show problems as i put rklci (or rpse) as the dependent variables. If i put other variables, "missing values" issue pops up.
Sincerely
price_volatility.wf1
daily stock index
(235.71 KiB) Downloaded 281 times
egarch1.prg
sample program of EGARCH in eviews
(2.4 KiB) Downloaded 346 times
cwlow48
Re: sample program of logl
Postby cwlow48 » Tue Dec 27, 2011 9:22 am
Below is the program which i have modified and there is problem.
as the dependent variable changes, problems occur.
' example program for EViews LogL object
' Estimate EGARCH with generalized error distribution (Nelson's specification)
' For discussion, see p. 668 of Hamilton, James D. (1994) Time Series Analysis,
' Princeton University Press.
'change path to data path
%path = @runpath
cd %path
' load workfile
load price_volatility
series rklci = 100*dlog(klci)
series rhkx = 100*dlog(hkx)
series ridx = 100*dlog(idx)
series rpse = 100*dlog(pse)
series rset = 100*dlog(set)
series rsse = 100*dlog(sse)
series rsst = 100*dlog(sst)
series rszse = 100*dlog(szse)
' set sample to 1/1/00-31/12/10 (31/12/10 is obs 2870)
sample s0 2 3
sample s1 4 2870
smpl s1
' get starting values from Gaussian EGARCH
equation eq1
eq1.arch(2,2,asy=2,egarch) ridx c rhkx(-1) ridx(-1) rklci(-1) rpse(-1) rset(-1) rsse(-1) rsst(-1) rszse(-1)
show eq1.output
' declare and initialize parameters
' coefs on lagged variance
coef(2) delta
delta(1) = eq1.c(15)
delta(2) = eq1.c(16)
' coefs on lagged resids
coef(2) alpha
alpha(1) = eq1.c(11)
alpha(2) = eq1.c(12)
' coef on asym term
coef(1) chi
chi(1) = eq1.c(12)/eq1.c(11)
' coefs on deterministic terms
coef(2) rho
rho(1) = 2*log(eq1.@se)
rho(2) = 0
' 0<nu<2 is thick tails; nu>2 is thin tails
coef(1) nu = 2
!pi = @acos(-1)
' set presample values of expressions in logl
smpl s0
series zeta = log(1+rho(2)*ndays)
series h = exp(rho(1))
series z = 0
series temp1 = @abs(z(-1)) + chi(1)*z(-1)
' set up EGARCH likelihood
' note that E|v{t-1}| is absorbed in overall constant rho(1)
logl ll1
ll1.append @logl logl
'zeta = unconditional mean of log(ht)
ll1.append zeta = log(1+rho(2)*ndays)
'log(lambda) p.668 last equation
ll1.append loggam1 = @gammalog(1/nu(1))
ll1.append loglam = -log(2)/nu(1) + 0.5*( loggam1 - @gammalog(3/nu(1)) )
ll1.append temp1 = @abs(z(-1)) + chi(1)*z(-1)
ll1.append log(h) = rho(1) + zeta + delta(1)*(log(h(-1))-zeta(-1)) + delta(2)*(log(h(-2))-zeta(-2)) + alpha(1)*temp1 + alpha(2)*temp1(-1)
ll1.append res = ridx - c(1)*h - c(2) - c(3)*rhkx(-1) - c(4)*ridx(-1) - c(5)*rklci(-1) - c(6)*rpse(-1) - c(7)*rset(-1) - c(8)*rsse(-1) - c(9)*rsst(-1) - c(10)*rszse(-1)
ll1.append z = res/@sqrt(h)
ll1.append logl = log(nu(1)) - loglam - (1+1/nu(1))*log(2) - loggam1 - 0.5*@abs(z/exp(loglam))^nu(1) - 0.5*log(h)
' estimate and display output
smpl s1
ll1.ml(showopts, m=1000, c=1e-5)
show ll1.output
Postby EViews Gareth » Tue Dec 27, 2011 9:53 am
Did you try different starting values?
cwlow48
Postby cwlow48 » Tue Dec 27, 2011 6:24 pm
Yes, i did. But the "missing value" problem is still there... Anything else i can do to resolve this?
Postby EViews Gareth » Tue Dec 27, 2011 7:56 pm
The only thing you can do is try to track down what is causing the missing value by looking at the constituent parts of the likelihood series and seeing what is causing the NA for that observation.
Ghulam Ali
Postby Ghulam Ali » Wed Jan 25, 2012 11:20 am
All Friends
I have no experience in programing. I have entered all the commands from program window to command window but i could not find the results of Dcc -garch model. The message which is received at the time of estimation is,"missing values @logl series at current coefficients at observation 1". In logl series data is missing. what is the proper command to estimate logl series. Help me I will be thankful.
Ghulam Ali
