dummy varibles help
diesel20056
dummy varibles help
can some help i have these varibles y x e t and want to make a dummy varible 1 if female ,0 otherwise can some one help as i need to see the differences between the males and females within the data thanks
Re: dummy varibles help
I don't quite understand the question. Could you elaborate?
diesel20056
there is data for 93 people the starting salary =Y education in years =X months of previous work experience =E the month in which the individual was hired =T with individuals hired in the first month having T=1 and those hired in the last month having T=36.
The first 61 observations are for female employees and the last 32 observations are or male employees.
i need to make a dummy varible so i can see if males do get a higher starting wage or not, hope that helps
The command
series female = @trend<61
creates the dummy variable with 1's for the first 61 observations, and 0's for the remainder (you should check that this lines up with what you expect). Just type that in the command line...
diesel20056
thanks alot that helped :D
diesel20056
Hey, how would I compute a equation to show the differences for the women and mens salaries side by side on the ols table
