Freequency Conversion
I work on a dataset of intraday stock prices at random time intervals. Is there any technique to convert observations at a regular time freequency ( i.e
5-min, 3-min, 60-min etc) ?
Many thanks in advance,
Panos
Panos
Re: Freequency Conversion
Could you be a bit more explicit in what you're trying to do?
I use time series of intraday stock prices at random price intervals, like:
time(HHMMSSmS) Price
10403015 10.50
10403110 10.52
10410101 10.80
11501021 09.80
I want to create a regularly spaced (in terms of time) data series, such as (suppose 5-min):
10403015 10.50
10453015 ?
10503015 ?
with the new price derived, will probably depending of the interpolation method.
any hint?
Thanks again
Panos
10403015 10.50
10403110 10.52
10410101 10.80
11501021 09.80
10403015 10.50
10453015 ?
10503015 ?
any hint?
Thanks again
Panos
The question is - what do you want to do with the prices that aren't on a 5 minutely interval?
Nothing. Just keep the last price at the 5-min interval ( or probably an average of them).
Is there any other option?
Thanks again
Panos
Thanks again
Panos
Create a new page that has the 5 minute interval structure you want, then copy from the irregular page to the new page.
Many many thanks indeed.
What if I want to keep the days when my observations are interpolated. My dataset is like:
Day time(HHMMSSmS) Price
01/06/2009 10403015 10.50
01/06/2009 10403110 10.52
01/06/2009 10410101 10.80
02/06/20009 11501021 09.80
When I actually do with copy paste it creates a time-series of 5-min prices by fewer days ( since a new column of days it's created by default), so I cannot match my real observations with their actual days.
Is there any way to construct this 5-min time series but with price observations still match their actual day.
Thanks sincerely
Panos
Thanks sincerely
Panos
I'm lost.
Perhaps you could provide the workfile, and an explanation of the steps you have taken, and an explanation of what is going wrong?
The data set starts on 01/06/2009 and ends on 31/05/2010
The steps are as follows:
1. Create new workfile 'Ave'
2. Open new page
3. Specify freequency/range .Set: - Freequency: Intraday
5-Minute
- Start Date : 06/09/2009 / End Date: 31/05/2010
- Days: 1.Monday - 5. Friday (only working days)
- Time: from 10:30:00 to 15:30:00
4. Paste created series
The workfile is attached. series04 is the price column and stops at 10/09/2009
Thanks again
Panos
2. Open new page
5-Minute
Thanks again
Panos
No attachment.
sorry I cannot upload the file
I pres"Add the file'' and the file disappears
How can I do that?
How can I do that?
just email it to support@eviews.com
File received.
The problem is that your first page is not structured as a dated page. Further, you can't structure it as a dated page because you have duplicate date/time pairs.
I can't help further without knowing what your intentions are with regards to the conversion from irregular/duplicates to a regular time frame. Again, what are you going to do if an observation isn't on the 5 minute mark, and what are you going to do if there are more than one observations on a 5 minute mark?
For what it is worth, I created a single date/time series in your first page with the following: (Might not be the most efficient way, but it worked!)
(the last two lines aren't necessary, but I included so that you can see the result nicely)
series time = @dateval(@left(@str(series03), 6) + "." + @right(@str(series03), 2), "HHMISS.SS")
alpha datetimestr = @datestr(series02, "YYYY/MM/DD") + " " + @datestr(time, "HH:MI:SS.SSS")
series datetime = @dateval(datetimestr, "YYYY/MM/DD HH:MI:SS.SSS")
datetime.setformat "YYYY/MM/DD HH:MI:SS.SSS"
show datetime
Hi guys,
i wanted to answer how i can to convert my (time series )data from 5-years observations to annual observations. I had downloaded a database which is like that:
1960: 7.2
1965:7.8
1970:8.4
and i want to convert them to annual data in eviews.
Thank you in advance.
1960: 7.2
1965:7.8
1970:8.4
