Hi guys,
For me programming Eviews is totally new, so I first worked through the guide available, but still haven't found what I was looking for.
In my case, I have got several dependent variables, but I know how to change those in a program.
However, I got several independent variables, of which some are fixed, and others are not. The first "fixed" variables are certainly needed for the regressions, but I want to know which other variables do give more explanation power. But I do not know how to implement this in my program.
So the regressions look like this:
y(1) = c + x(1) + x(2) +x(3) + x(4) + x(5) + x(6) + x(v1)
y(1) = c + x(1) + x(2) +x(3) + x(4) + x(5) + x(6) + x(v2)
y(1) = c + x(1) + x(2) +x(3) + x(4) + x(5) + x(6) + x(v3)
y(2) = c + x(1) + x(2) +x(3) + x(4) + x(5) + x(6) + x(v1)
y(2) = c + x(1) + x(2) +x(3) + x(4) + x(5) + x(6) + x(v2)
y(2) = c + x(1) + x(2) +x(3) + x(4) + x(5) + x(6) + x(v3)
y(3) = c + x(1) + x(2) +x(3) + x(4) + x(5) + x(6) + x(v1)
y(3) = c + x(1) + x(2) +x(3) + x(4) + x(5) + x(6) + x(v2)
y(3) = c + x(1) + x(2) +x(3) + x(4) + x(5) + x(6) + x(v3)
Is there a way to programm this, and if so, can somebody tell me how?
Thanks a lot in advance
Multiple regressions and changing independent variables
PeterDeJongh
Re: Multiple regressions and changing independent variables
What have you done so far?
PeterDeJongh
Not too much I guess. I used the program from the "introductions" part on this website, which creates different regressions for all variables using the loops etc.
I sort of rewrote it to make it accessable for my own dataset.
This is what I got so far:
for !i=1 to sectors.@count
%iname = sectors.@seriesname(!i)
for !j=1 to control.@count
%jname = control.@seriesname(!j)
for !k=1 to commodities.@count
%kname = commodities.@seriesname(!k)
eq.ls {%iname} c {%jname} {%kname}
r2s(!rowcounter) = eq.@r2
!rowcounter = !rowcounter+1
Point is though, that from the "control" group, all the variables should allways be in the regressions. Probably this is a pretty simple command, but I do not know how to implement this in the program control window.
Thanks in Advance!!
Thanks in Advance!!
If the control group is always in the regression, you don't need to loop over it:
%control = control.@members
eq.ls {%iname} c {%control} {%kname}
