@jprob for panel GMM equation (EV7)
nadja123
Postby nadja123 » Fri Oct 21, 2011 10:31 am
Hello there,
the command
scalar myjprob = eq01.@jprob
does "successfully compute" the p-value, but the value is actually NA. (Doing it other way gives a numeric value). Is this a bug?
Re: @jprob for panel GMM equation (EV7)
Postby EViews Gareth » Fri Oct 21, 2011 11:05 am
That's a really cryptic statement. What do you mean?
nadja123
Postby nadja123 » Sat Oct 22, 2011 1:08 pm
How would I tell you... Suppose quation eq01.gmm(options) has been estimated in a balanced panel workfile. Then
scalar myf*** = eq01.@jstat
computes the J-statistic. I want the p-value to J-statistic. In the help doc to EV7 there is mentioned
@jprob probability value of the J-statistic
as one of the equation data members. How to get that computed? Thank you.
Postby EViews Gareth » Sat Oct 22, 2011 1:56 pm
Still not quite sure I follow your question, but perhaps the following will help:
create u 100 rndseed 1 series y=nrnd series x=nrnd series z1=nrnd series z2=nrnd equation eq1.gmm y c x @ z1 z2 scalar auto = eq1.@jprob scalar manual = 1 - @cchisq(eq1.@jstat, 1)
You can see that the scalar calculated by eq1.@jprob is equal to the scalar calculated manually using the j-stat.
Postby EViews Glenn » Mon Oct 24, 2011 9:26 am
From what he says it might be in the panel equation estimator not the standard GMM. Can you send your workfile to support@eviews.com or post it here...Let us know what equation it is...
[edit]
We've replicated on this end. The @jprob keyword was added to EVIews 7 equations in the improvements to single equation GMM, but we neglected to update the earlier panel code. This will be fixed in the next update. For now, just use the @ncoefs, @jstat, @instrank members of the equation and the @chisq function to compute the p-val...
