Running a regression with exponential form
wing0011
Postby wing0011 » Sun Sep 25, 2011 5:12 am
I've been asked to run a regression with an exponential from... but I don't know what should be typed in in eviews, please help!!!!
my regression is: E (lwage|exper, educ) = b0 +b1exper +b2(1-exp (b3*educ))
Don't know how to do because not sure how to deal with the things that inside the bracket, since b3 is inside the exp...
have tried to expand the whole equation, but still cannot solve the problem of b3 inside the bracket.
Thanks a lot in advance!
Re: Running a regression with exponential form
Postby startz » Sun Sep 25, 2011 8:37 am
EViews is perfectly happy to run a nonlinear regression where you write out an explicit formula using c(1), c(2), etc. for the names of the coefficients.
For instance
ls y = c(1) + exp(c(2)*x)
wing0011
Postby wing0011 » Mon Sep 26, 2011 6:04 am
Thank you so much, startz!
I have tried, it works!!!
agamonim
Postby agamonim » Sat May 19, 2018 7:26 am
Thank you so much!! My regression is similar and writing the equation in this way worked for me.
