program variables of Addin can not be used outside
For tips, questions and general information about writing Add-ins, how to package them, and how to submit them to EViews for publication.
maxchen
Postby maxchen » Tue Aug 30, 2011 12:59 am
!doR2 is defined in the eqsumtab.prg of EqTabs Addin
%ex7 = "\Example Files\EV7 Manual Data\" %ch2 = "Chapter 2 - A Demonstration" %wf = @evpath + %ex7 +%ch2 +"\demo.wf1" pageload %wf eqsumtab eq* 'save in table "results", and @getnextname 'rename {%tabname} tbeqs 'no effect c(1) = !doR2 'error
also, %tabname is defined in eqsumtab.prg, but can not be used outside the Addin in the line "rename {%tabname} tbeqs"
Re: program variables of Addin can not be used outside
Postby EViews Gareth » Tue Aug 30, 2011 7:50 am
Yep.
maxchen
Postby maxchen » Tue Aug 30, 2011 6:44 pm
Thanks, but the object created in Addin is not local, say live in the workfile, and can be accessed by the main prg file.
Postby EViews Gareth » Tue Aug 30, 2011 7:15 pm
Correct. Workfile objects belong to workfiles, program variables belong to programs. When you delete a workfile, all objects in that workfile are gone, even if you're still running the program that created them. When you exit a program, all program variables in it are also gone, but the workfile objects it created are left behind.
Return to “Add-in Writing area”
