logmode and prg line number
maxchen
Postby maxchen » Mon Aug 29, 2011 7:17 pm
ver EViews7Patch_082511.exe
logmode -hideprogline all 'work, but not see line number 'logmode debug 'can not find the log window wfcreate u 7 c(1) = @verstr 'error
the log message are as follows, but no line number is recorded
wfcreate u 7
c(1) = @verstr
Non numeric argument in "C(1) = @VERSTR".
Re: logmode and prg line number
Postby EViews Gareth » Tue Aug 30, 2011 7:51 am
I'm not sure what you're asking here Max.
maxchen
Postby maxchen » Tue Aug 30, 2011 6:15 pm
hmm, I mean the line number is not show in the log, for example
4 wfcreate u 7
5 c(1) = @verstr
Non numeric argument in line 5 "C(1) = @VERSTR".
Postby EViews Jason » Wed Aug 31, 2011 11:11 am
The documentation is incorrect. The documentation for 'logmode' currently reads
hideprogline/-hideprogline [Hide/Do not hide] the program line number when reporting errors encountered during execution.
It should read
hideprogline/-hideprogline [Hide/Do not hide] the program line when reporting errors encountered during execution.
To elaborate on this, normally when an error is encountered in a program you will get 2 things: 1)the error and 2)the program line generating the error.
For example, if you run the program:
create u 10 show x
you will get the error
X is not defined in "SHOW X".
But if you add 'logmode hideprogline' such that you have
logmode hideprogline create u 10 show x
the program line is suppressed and you will get the error
X is not defined.
