Panel Data - Quantile Regression
tompan
Postby tompan » Fri Jul 15, 2011 4:12 am
I have a panel data set and one of the options that appear is quantile regression.
would it be possible to let me know what exactly is EViews estimating in this case?
regards
Re: Panel Data - Quantile Regression
Postby EViews Gareth » Fri Jul 15, 2011 8:03 am
It is estimating a standard quantile regression on the stacked data, with the exception that any lags you have will not cut across cross-sections. Assuming you have no lags, it will give identical results to performing quantile regression without the panel structure. I.e. the estimation has nothing "panel" about it.
tompan
Postby tompan » Fri Jul 15, 2011 8:17 am
If i created the lags of the variables i want to include in my model in excel
and add them as variables in my panel set later on
would my estimation be correct?
Postby EViews Gareth » Fri Jul 15, 2011 8:23 am
That question is impossible to answer.
theodore04
Postby theodore04 » Fri Jul 15, 2011 8:34 am
so is it performing a cross section quantile regression irrespective of the cross section and the time dimension?
Postby EViews Gareth » Fri Jul 15, 2011 8:42 am
Sort of. If you have no dynamics in your equation (i.e. no lags), then yes, you can think of it as one big cross-section quantile regression.
