Substituting Variables in an Equation
jennie
Postby jennie » Fri Jul 08, 2011 11:19 am
I am currently estimating parameters for a fairly large equation.
I would like to be able to try different forumlae within the equation.
In order to manage this and make the code more readable and flexible I am trying to use variables within an equation so that I can change parts of it.
For example something like this:
weight = p^c(1) / ( p^c(1) + (1-p)^c(1) )^ (1/ c(1))
value1 = z1 ^ c(2)
value2 = z2 ^c(2)
equation = weight * value1 + (1-weight ) * value2
However, when I write my code I am not substituting/ using variables correctly.
I guess I am just trying to figure out how to merge separate equations together in order to then estimate the parameters of a larger equation.
Here is something like what I have written:
'First I use some variables to store a series name so that I can trade these out as necessary 'nn_p1, nn_z1, nn_z2 are each a series %p1 = "nn_p1" %z1 = "nn_z1" %z2 = "nn_z2" ' %Gamma and %Alpha are each coefficients (c(1) and c(2)) that I will be estimating. ' I need to constrain them so I have taken them each separately here.... %gamma = "(1.99 * @logit(c(1)) + 0.01)" '<--- constrain gamma between 0.01 and 2 (H-L)*@logit(c(1)) +L %alpha = "(9.999 * @logit(c(2)) + 0.001)" ' Three equations here: weight, value1 and value 2 ' I want to merge them together to make a larger equation %weight = {%p1} ^ {%gamma} / ( {%p1} ^ {%gamma} + ( 1-{%p1} ) ^ {%gamma} )^ (1/ {%gamma} ) %value1 = "{%z1}^{%alpha}" %value2 = "{%z2}^{%alpha}" 'Here I am trying to estimate coefficients c(1) and c(2) by merging together the 3 equations from above equation eq.ls {%weight} * {%value1} + (1- {%weight}) * {%value2}
Any advice on perhaps a technique or object I could use to accomplish this would really be appreciated!
Thanks,
Jen
Re: Substituting Variables in an Equation
Postby EViews Gareth » Fri Jul 08, 2011 11:28 am
You've created %gamma and %alpha correctly, but not %weight and %value1 and 2.
All % variables are just strings. Therefore they need quotes around each part that you're building up.
Something like:
%weight = %p1 + "^" + %gamma + "/(" + %p1 + "^" + %gamma + "(1-" + %p1 + ")^" + %gamma + ")^(1/" + %gamma + ")" %value1 = %z1 + "^" + %alpha
jennie
Postby jennie » Fri Jul 08, 2011 11:46 am
Oh I see...
I will give this a try
