I would like ot know if there's a way that Eviews can import data that is in reverse chronological order in Excel? The data is a regular weekly time series, in columns, with the last value appearing first. Dates are in column A, data in column B.
Thanks for your help.
Import data from Excel - Reverse chronological order
- OSB Prices.xlsx
- (11.16 KiB) Downloaded 461 times
Re: Import data from Excel - Reverse chronological order
Sure. The only problem with that file is the first row and last row. If you tell EViews to ignore those rows (telling it to import the range A2 to B105), it will work fine.
