I have 24 regression equations outputs. I need to copy and paste these into microsoft excel.
d = 100 + 4*dd^5 + 6*dd^6 + 0.5*dd^7
d = 1.2*te + 5*dd^2 + 0.05*dd^7 ...etc
Instead of copying and pasting each equation, is there a way i can save the above form of the equation as a string perhaps, and save it in a table? then i can just copy and paste the table in one go.
e.g.
table mytable
mytable(1) = " d = 100 + 4*dd^5 + 6*dd^6 + 0.5*dd^7 "
mytable(2) = " d = 1.2*te + 5*dd^2 + 0.05*dd^7 " ....etc
many thanks
Minson
equation outputs into table?
Re: equation outputs into table?
Unfortunately there isn't an easy way to do this...
The best I can think of is to put all of the equations into a spool, then write the spool to an RTF file, open it in Excel and delete all the stuff you don't want.
A second, perhaps better way, is to put all your equations into a model, then break the model links (Proc->Links->Break All Links), then look at the source text of the model (View->Source Text). That should give you something closer to what you want.
Putting an equation into a model then breaking the links works superbly for one equation. But as soon as I try to add another equation, I get a message in the model saying,
" d is specified as endogenous in another equation in est(1) "
Anyway ideas how I can work around this?
Ah, good point - if they have the same dependent variable, I'm not sure you can get them into a model like that.
Ok, for those who are interested, I have gone round the problem in the following way. Not ideal, but it kind of does the bulk of what I wanted:
create a for loop for !hour = 1 to 24- with the loop do the follow steps
- set the sample
- create a new temporary series, with a unique name and set it to the orinal series you wanted to regress on. In this case that original series is called "d".
%temp_series = "d" + !hour
series{%temp_series} = d
- run the regress on this uniquley named variable
- save the equation to a model
- delete temp_series and the equation if you dont want them
go into the model then do what qms gareth suggested "break the model links (Proc->Links->Break All Links), then look at the source text of the model (View->Source Text). "
This method is not perfect because you have different variable, d1 = , d2 = , d3 = ..etc. at the beginning of each equation, which you need to change manually, but thats not too time consuming. Let me know if there is a better way.
- set the sample
