URGENT: AIC and SBIC criterion for forecasts
stasibab
Postby stasibab » Fri Jun 10, 2011 12:26 pm
I would like to now if it is possible to estimate the bic and aic criterion for some forecasts.
For example if I have the 3 forecast results f1,f2,f3 and the original series 'sample'
if i perform a regression for each one, meaning for example dependant variable sample and independent f1, I will get AIC1 and BIC1? Am I right??
Thanx in advance!
Re: URGENT: AIC and SBIC criterion for forecasts
Postby EViews Gareth » Fri Jun 10, 2011 2:25 pm
I don't understand the question.
If you run a simple regression, then, yes, the output will produce AIC and BIC.
stasibab
Postby stasibab » Fri Jun 10, 2011 2:35 pm
The point is to estimate the quality forecast by the bic and sic, I was just not sure if to get the bics and sics have to do a simple regression with each one or with all the forecasts together like: dependant sample and independent f1 f2 f3 ;
it is just when I use one forecast the bics and sics of all three are almost equal and I thought that I did something wrong...
Postby EViews Gareth » Fri Jun 10, 2011 2:47 pm
Well it isn't clear what you mean by "AIC of forecast". The AIC is a statistic based upon a likelihood function. I don't see how that fits in with a forecast.
stasibab
Postby stasibab » Fri Jun 10, 2011 2:57 pm
To make it more clear I have two series f1, f2 and I want to calculate their AIC1,AIC2 and BIC1,BIC2! This is what I want. I am a bit confused on how to do it with eviews...
Postby EViews Gareth » Fri Jun 10, 2011 3:02 pm
A series doesn't have an AIC, thus your question doesn't make sense.
stasibab
Postby stasibab » Fri Jun 10, 2011 3:07 pm
Gareth I know this will make you laugh, but your last comment just cleared my mind on a lot of things I was troubled!! Sorry for the stupid question and thank u for the immediate response!!
