I'm trying to exclude some periods of a endog variable for two reasons:
1-From @first to 1995.4 it generates log of non-positive numbers
2-As it's a annual variable, 3of the 4 trimesters has a NA
As I found, there is a possibility to call exclude in the "Scenario excludes" section. It works for both of them, but only seperately.
__alexis.exclude VAR( "IF VAR = NA")
__alexis.exclude VAR("@first 1995.4")
But, if I merge them together like __alexis.exclude VAR("@first 1995.4", "IF VAR = NA"), it doesn't work... So I would like to know if there's a way to do it or it's not possible.
Thank you!!!
Scenario exclude
Re: Scenario exclude
Try:
__alexis.exclude VAR("IF VAR = NA or @date<@dateval("1995.4")")
