Copy Command Options
modelmaker
Postby modelmaker » Tue Jun 07, 2011 9:00 am
I have two questions regarding the 'copy' command:
(1) When I copy series between pages, the 'link' option doesn't appear to work:
copy(link) annual\series1 quarterly\series1
(2) I am having trouble getting the 'smpl' option to work. The copy command seems to automatically merge any available data within the workfile range:
copy(m,smpl="1970 2009") db1::series2 wf::series2
Thanks.
Re: Copy Command Options
Postby EViews Gareth » Tue Jun 07, 2011 9:07 am
The link option is for creating database links, not links between pages. Use a link object if you want to create a link between two pages.
I'm not sure if the smpl option works when copying from a database.
modelmaker
Postby modelmaker » Wed Jun 08, 2011 11:26 am
With regard to the "smpl" option, I tried the following code:
series series1 fetch(c=nu,d=db1) series2 copy(m,smpl="1971Q1 1990Q4") wf::series2 wf::series1
Even when copying within the same workfile page, the "smpl" option doesn't seem to work. Everything in series2 gets copied into series1. Any suggestions?
(Forgot to mention - I'm using EViews 7 Enterprise Edition.)
Postby EViews Gareth » Wed Jun 08, 2011 11:37 am
Seems to work for me:
wfcreate(page=page1) m 1990 2010 series y=nrnd pagecreate(page=page2) m 1990 2010 copy(smpl="1993 1995") page1\y page2\y show y
modelmaker
Postby modelmaker » Wed Jun 08, 2011 12:30 pm
Your code works, but why doesn't this code work?:
wfcreate(page=page1) m 1990 2010 series y=db::lr series z copy(m,smpl="1993 1995") y z show z
Postby EViews Gareth » Wed Jun 08, 2011 1:13 pm
The copy command isn't really meant for copying series into the same page. You can use simple = assignment to do that:
smpl 1993 1995 series z = y
