ARIMA (0,1,0)
fatyma
ARIMA (0,1,0)
Postby fatyma » Fri Apr 29, 2011 6:31 am
I have a problem regarding Box jenkins ARIMA method of forecasting
I have exports in US dollars at constant prices . There are 50 0bservations. The series was non stationary as indicated by ADF test. Moreover, ACF correlogram has shown a linear decay to zero whereas PACF shows a signifcant spike at lag 1 and then cut off to zero. After taking first differencing series has became stationary, and ACF, PACF shows no significant spikes. Thus model chosen was ARIMA(0,1,0) a random walk model without drift. However estimating this model yields an output with AR inverted roots greater than 1 and output gives a message that AR(1) is non stationary. why is it happening,although correlogram-Q statistic of residuals test shows no autocorrelation.
I am attaching my excel file for the data series so that one could check my problem
Table 6_8.xls
(18 KiB) Downloaded 540 times
fatyma
Re: ARIMA (0,1,0)
Postby fatyma » Mon May 02, 2011 4:40 am
It is very disappointing that no one has replied to my problem not even the eviews moderators. this is extremely astonishing. I wasant expecting this kind of response from eviews moderators
Re: ARIMA (0,1,0)
Postby startz » Mon May 02, 2011 7:01 am
You haven't asked a question about EViews.
The Econometric Discussions section is a provided as a courtesy.
bianca825
Contact:
Re: ARIMA (0,1,0)
Postby bianca825 » Wed Oct 05, 2011 4:35 am
It's a pitty, I also have some questions about arima, but you are right, we should look for an appropriate forum
Web Application Mania
