Rolling Chow Tests
redbull64
Rolling Chow Tests
Postby redbull64 » Wed Apr 27, 2011 3:18 am
I apologise in advance if this has a really simple solution that I've overlooked (although I hope it does!).
I have estimated a linear regression and am trying to run a rolling chow test in order to identify any break points in my sample period.
Ideally I'd like a graph showing the observation number on the x-axis and the Chow F statistic (or corresponding p-value) on the y axis.
I couldn't find any specific function to do this, and have spent ages trying to write a program that will do it for me, but to no avail.
Any help would be VERY gratefully received. :D
Re: Rolling Chow Tests
Postby EViews Gareth » Wed Apr 27, 2011 7:55 am
Should be relatively straight forward. Just a for loop that loops over the dates/observations you want to perform the chow test on, then freeze each chow test into a table, and extract the test statistics.
Of course, an easier way would seem to be to use the Quandt Andrews test instead, since that is just a Chow test at every point.
