save ARMA root to matrix
bandita9
Postby bandita9 » Tue Apr 12, 2011 7:48 am
Hi!
I wrote a little program to estimate the best ARMA structure by SIC. But i need them to forecast. But there are a lot of nonivertible MA in the estimations.
So i wanted to save the root to a matrix. But the following command didnt work:
asd2005q3.arma (type=root, save=root)
I typed that, than just the window popped up. What should i do to get the best ARMA with invertible MA roots?
I used the following program:
wfopen K:\potencialis\adatok
for !s=29 to 62
%1 = @otod(!s)
smpl 1995q1 %1
genr dlog_fogl = dlog(fogl)
%y_nev = "dlog_fogl" ' ## Ezt az idősort modellezzük
!l = 4 ' ## Tekintett késleltetések maximuma
' ** Táblázat
%tbl_nev = %y_nev + "_arma"+ @otod(!s)
d {%tbl_nev}*
table {%tbl_nev}
{%tbl_nev}(1,1) = "ARMA modellek a " + %y_nev + " változóra"
{%tbl_nev}(2,1) = "AR"
{%tbl_nev}(2,2) = "MA"
{%tbl_nev}(2,3) = "AIC"
{%tbl_nev}(2,4) = "SIC"
!minaic = 1000000
!minsic = 1000000
' ** Dupla ciklus p-re és q-ra
for !p=0 to !l
for !q=0 to !l
statusline AR !p MA !q
%eqnev = "eq_ar"+@str(!p)+"_ma"+@str(!q)
' ** Létrehozza az MA(1) ... MA(q) szöveget
%argma=""
if !q>0 then
for !i=1 to !q
%argma=%argma+" MA("+@str(!i)+")"
next '!i
endif
' ** Létrehozza az AR(1) ... AR(p) szöveget
%argar=""
if !p>0 then
for !j=1 to !p
%argar=%argar+" AR("+@str(!j)+")"
next ' !j
endif
%arg=%y_nev + " C " + %argma + %argar
' ** Egyenlet és AIC & SIC értékek
if (!p+!q)>0 then
equation {%eqnev}.ls {%arg}
{%tbl_nev}(2+!p*(!l+1)+!q,1)=@str(!p)
{%tbl_nev}(2+!p*(!l+1)+!q,2)=@str(!q)
{%tbl_nev}(2+!p*(!l+1)+!q,3)=@aic
{%tbl_nev}(2+!p*(!l+1)+!q,4)=@schwarz
' ** AIC & SIC minimumkeresés
if @aic < !minaic then
!minaic = @aic
!p_aic = !p
!q_aic = !q
endif
if @schwarz < !minsic then
!minsic = @schwarz
!p_sic = !p
!q_sic = !q
endif
d {%eqnev}
endif
next ' !q
next ' !p
{%tbl_nev}((!l+1)^2+3,1)= "AIC szerinti legjobb: ARMA(" + @str(!p_aic) + "," + @str(!q_aic) + ")"
{%tbl_nev}((!l+1)^2+4,1)= "SIC szerinti legjobb: ARMA(" + @str(!p_sic) + "," + @str(!q_sic) + ")"
if !p_aic=2 then
%asd="asd" + @otod(!s)
equation {%asd}.ls dlog(fogl) c ar(1)
endif
%arga=""
if !q>0 then
for !i=1 to !q_aic
%arga=%arga+" MA("+@str(!i)+")"
next '!i
endif
%argr=""
if !p>0 then
for !j=1 to !p_aic
%argr=%argr+" AR("+@str(!j)+")"
next ' !j
endif
%argt=%y_nev + " C " + %arga + %argr
equation {%asd}.ls {%argt}
Re: save ARMA root to matrix
Postby EViews Gareth » Tue Apr 12, 2011 7:55 am
You have a space between the arma and the parenthesis.
bandita9
Postby bandita9 » Tue Apr 12, 2011 8:04 am
Thx!
