Date Period using WFOPEN
PacNW
Postby PacNW » Fri Apr 01, 2011 4:50 pm
I am a recent convert to EViews 7 and I am using WFOPEN for the first time.
I have an xlsx file:
1st row is Headers
1st Column is dates (daily, of the format: m/d/yyyy)
Using wfopen, EViews is reading everything correctly, except it is reading in the date column as a separate variable, and each series has no dates.
Is there an option for WFOPEN where you set the sample for the columns being read in? Or do you use another command to add dates to each of the imported series? If it is the latter, what is the best way to do this?
Thanks!
PacNW
Re: Date Period using WFOPEN
Postby PacNW » Fri Apr 01, 2011 4:53 pm
Just figured out it was @date... you can ignore my question.
Users browsing this forum: paues and 2 guests
