OLS with Variable Independent Variables
Jun
Postby Jun » Wed Mar 16, 2011 3:50 am
When I tried to run the following OLS procedure, I got the error message "%CURRENTSERIES(0 TO -12) is not a valid string or scalar name."
And when I place the "(0 TO -12)" outside the braces i.e. {%currentseries}(0 to -12), I get the error message "0TO is not defined." The message is "0TO" and not "0 TO -12" so I guess the brackets () are not read by the program.
Basically I'm trying to regress {%independent} on {%currentseries} with up to 12 lags.
Anyway around this or do I have to create another group for the lags first?
%independent=@wlookup("d?_*","series")
for !i=1 to @wcount(%independent)
%currentindependent=@word(%independent,!i)
%currentseries=@wlookup(%currentindependent,"series")
equation eq{!i}.ls(cov=hac) {%dependent} c {%currentseries(0 to -12)}
Re: OLS with Variable Independent Variables
Postby EViews Gareth » Wed Mar 16, 2011 7:54 am
equation eq{!i}.ls(cov=hac) {%dependent} c {%currentseries}(0 to -12)
And to check it works, run this:
create u 100 series y=nrnd series x=nrnd %dependent = "y" %currentseries = "x" equation eq.ls(cov=hac) {%dependent} c {%currentseries}(0 to -12)
Jun
Postby Jun » Wed Mar 16, 2011 4:57 pm
Hi Gareth,
Can you explain why the following works? I don't get it.
%dependent = "y"
So now this works...BUT what should I do if I want to see the names of my independent variables in each "eq" output? Now they're all X's.
series y = nrnd
series x = nrnd
%dependent = "y"
Postby EViews Gareth » Wed Mar 16, 2011 5:05 pm
I don't understand your question.
Jun
Postby Jun » Wed Mar 16, 2011 5:16 pm
I think I got it...thanks
series y = {%dependent}
series x = {%currentseries}
%dependent = "y"
