EGARCH
puf
EGARCH
Postby puf » Tue Mar 15, 2011 3:02 am
I would like to do a rolling window forecast with EGARCH model. The following code:
wfopen 28.csv series logr = dlog(abs(prc)/cfacpr) series true_vol = logr^2 series forecasted_garch4 scalar estimation_window = 400 scalar length = @obsrange for !i=estimation_window to length-2 smpl @first+!i-estimation_window @first+!i equation kamo4.ARCH(egarch) logr smpl @first+!i+1 @first+!i+1 kamo4.forecast r se var forecasted_garch4(!i+2)=var(!i+2) next smpl @first+estimation_window+1 @last scalar num_obs = @obssmpl scalar RMSE= @sqrt((@sumsq(forecasted_garch4-true_vol))/num_obs)
works for most of the stocks (27 out of 30), but for three of them it gives the following error message:
Overflow in "do_kamo4.forecast r se var"
could you please fix this problem?
28.csv
(470.49 KiB) Downloaded 637 times
Re: EGARCH
Postby EViews Gareth » Tue Mar 15, 2011 8:03 am
I'm not sure this is a bug. The estimation on that particular stock failed - it couldn't converge. Therefore it couldn't forecast particularly well and led to an overflow.
puf
Re: EGARCH
Postby puf » Tue Mar 15, 2011 2:50 pm
I do not think that you are right. The error message says that what failed was just forecasting, not estimation itself. And indeed, when you delete from the code the lines for forecasting, the code works, there is no error message.
please tell me what the problem is (and eventually fix it)
Re: EGARCH
Postby EViews Gareth » Tue Mar 15, 2011 3:12 pm
The problem is that your estimation did not converge. Therefore you cannot forecast from it. When an estimation does not converge, EViews does not produce an error, rather it just prints out in the estimation output that it didn't converge.
