Panel Cointegration Technique and FMOLS
Posted: Thu Feb 24, 2011 1:55 am
by bleuenrouge
Hello!
Are the Panel Cointegration technique and Fully Modified Ordinary Least Square already available in Eviews? In which version? Thanks! :D
Re: Panel Cointegration Technique and FMOLS
Posted: Thu Feb 24, 2011 8:54 am
Panel cointegration is not built into EViews. FMOLS is available as a built in procedure.
Posted: Thu Feb 24, 2011 10:39 am
by bleuenrouge
Okay, thank you very much for your reply. :)
Posted: Thu Feb 24, 2011 11:06 am
by bleuenrouge
Lastly, Does it mean I can no longer use Eviews for Panel Cointegration? I would just like to know because I will be using the Panel cointegration test and Fully Modified Ordinary Least Squares using "Panel Data."
Thank you again. :)
Posted: Thu Feb 24, 2011 11:27 am
Panel cointegration testing is built into EViews 7, however panel cointegration estimation is not.
Posted: Thu Feb 24, 2011 11:31 am
by bleuenrouge
Thank you for your reply. :)
