Panel Cointegration Technique and FMOLS
bleuenrouge
Postby bleuenrouge » Thu Feb 24, 2011 1:55 am
Hello!
Are the Panel Cointegration technique and Fully Modified Ordinary Least Square already available in Eviews? In which version? Thanks! :D
Re: Panel Cointegration Technique and FMOLS
Postby EViews Gareth » Thu Feb 24, 2011 8:54 am
Panel cointegration is not built into EViews. FMOLS is available as a built in procedure.
bleuenrouge
Postby bleuenrouge » Thu Feb 24, 2011 10:39 am
Okay, thank you very much for your reply. :)
bleuenrouge
Postby bleuenrouge » Thu Feb 24, 2011 11:06 am
Lastly, Does it mean I can no longer use Eviews for Panel Cointegration? I would just like to know because I will be using the Panel cointegration test and Fully Modified Ordinary Least Squares using "Panel Data."
Thank you again. :)
Postby EViews Gareth » Thu Feb 24, 2011 11:27 am
Panel cointegration testing is built into EViews 7, however panel cointegration estimation is not.
bleuenrouge
Postby bleuenrouge » Thu Feb 24, 2011 11:31 am
Thank you for your reply. :)
