Hello users of this list. I am starting to discover eviews programming capabilities. I have 8 eviews files where I recently ran the following stepwise program (one program that applies for all files, just changing the isin number each time):
'isin 169
wfopen "D:\data\isin169.wf1"
smpl if ano>=2009
equation eqSW.stepls(method=uni,btol=0.05,back) logliq c @ logsap l1liq l2liq l3liq l4liq l1sap l2sap l3sap l4sap liqmk pprom sem dv
wfsave "D:\data\isin169.wf1"
wfclose
What I would like to know is how can I extract the results of the final stepwise equation into a txt or xls file. I want to extract the variables, the coefficients, the p-values and the values for 3 tests: Jarque-Bera, White heteroskedasticity and Breusch-Godfrey for autocorrelation.
Thanks for your help
exporting results derived from a program
Re: exporting results derived from a program
freeze(mytable) eqSW.stats
mytable.save(t=rtf) d:\data\myoutput.rtf
thanks Gareth, but I think that I need something like your post on "http://forums.eviews.com/viewtopic.php?f=15&t=1631". Since I'm starting to develop skills in eviews programming, where can I see the syntax that I need to use in order to include in the equation output table the values for Jarque-Bera and its p-value, Breusch-Godfrey (4 lags) and its p-value and White heteroskedasticity test and its p-value?
I tried applying the code lines you sent me on each of the the 8 individual files, but it seems like I have something wrong since I only got one table. I mention this, since my wish is to apply my program and get the summary table for all the 8 final models produced.
- stepwise1.prg
- program for stepwise
- (2.59 KiB) Downloaded 316 times
If you want statistics that are not part of the standard equation output, you'll have to freeze those into tables too. Something like:
freeze(mytable2) eq.hettest
the info was very helpful... but i wonder if there's a way to extract results from a x12 ARIMA output..
the thing is I need to evaluate x12 forecast SE, upper and lower bands... I have the txt output but I need only the forecast part, it's very troublesome to extract that to an excel worksheet manually... please let me knoew if there's a way to do so.
thanks in advance
thanks in advance
Not easy.
The best thing you'll be able to do is freeze the X12 output text into a text object, then save that text object to disk as a text file, then see if Excel can make any sense out of the text file.
Something like:
Something like:
freeze(mytxt) y.X12
mytxt.save c:\temp\x12output.txt
thanks I was doing that... hoped there was some other though
I got another question... i use the code to save the x12 output ina a txt file, but i use it en 20 series in a eviews workfile so everytime a run the program i got 20 new windows with the output... is there any way to disable this windows to appear???
thank in advance
thank in advance
Try putting "do" at the start of the line with the command.
