EViews stop working when running GMM Breaktest Program
kusdhianto
Postby kusdhianto » Fri Feb 04, 2011 11:02 am
hello all,
I successfully ran GMM estimation and performed breaktest using Breakpoint test... menu.
But when I ran a simple program:
freeze(BREAK) eq_1.breaktest 2000m1
the equation name has been checked,it is correct, but EViews always stops working when I run the code.
I am using EViews7.1 and the latest update has been installed. Previously, I have successfully created rolling gmm program code, created program for storing the parameter estimates, etc, but only the breaktest program above that failed. I really need help on this.
Thank you.
Re: EViews stop working when running GMM Breaktest Program
Postby EViews Gareth » Fri Feb 04, 2011 11:06 am
Could you post your workfile?
