Chart with date axis from [t-x to t+x]
Posted: Thu Jan 27, 2011 9:17 am
by javiersan
Is it possible to do this type of chart?
- chart1.JPG (82.36 KiB) Viewed 6850 times
Thanks,
Javier
Re: Chart with date axis from [t-x to t+x]
Posted: Thu Jan 27, 2011 10:33 am
There's nothing built in that will do it. You can do it with some trickery though. See below:
create a 1970 2002
series NewZealand = rnd
series Australia = rnd
series Canada = rnd
series uk = rnd
'use 1989 as the base year
series Can1989 = canada
series Aus1989 = australia
series NZ1988 = newzealand(-1)
series nz1996 = newzealand(+7)
series uk1980 = uk(-9)
group g can1989 aus1989 nz1988 nz1996 uk1980
smpl 1983 1995
freeze(gr) g.line
alpha obslab = @str(@year-1989)
gr.setobslabel(series) obslab
show gr
Posted: Thu Jan 27, 2011 11:13 am
by javiersan
Interesting way of doing it. Thanks.
Posted: Thu Jan 27, 2011 11:26 am
But there should be a way to do this. Wanting to show before vs after "event" data is pretty common.
Posted: Fri Jan 28, 2011 8:19 am
by javiersan
I am almost sure that the following chart is not possible to do without manual fiddling of the date axis with addtext(s) (as I was doing with the chart types above before Gareth's stunned me with his super simple solution). It could be great if these types of double date axis charts were built into future Eviews versions.
- double_scale.JPG (25.64 KiB) Viewed 6814 times
Cheers,
Javier
Posted: Fri Jan 28, 2011 9:02 am
Yeah, I can't think of another way to get that double scale. If we allowed carriage returns in obs labeling, it would be easy, but we don't :(
