Chart with date axis from [t-x to t+x]
javiersan
Postby javiersan » Thu Jan 27, 2011 9:17 am
Is it possible to do this type of chart?
Thanks,
Javier
Re: Chart with date axis from [t-x to t+x]
Postby EViews Gareth » Thu Jan 27, 2011 10:33 am
There's nothing built in that will do it. You can do it with some trickery though. See below:
create a 1970 2002 series NewZealand = rnd series Australia = rnd series Canada = rnd series uk = rnd 'use 1989 as the base year series Can1989 = canada series Aus1989 = australia series NZ1988 = newzealand(-1) series nz1996 = newzealand(+7) series uk1980 = uk(-9) group g can1989 aus1989 nz1988 nz1996 uk1980 smpl 1983 1995 freeze(gr) g.line alpha obslab = @str(@year-1989) gr.setobslabel(series) obslab show gr
javiersan
Postby javiersan » Thu Jan 27, 2011 11:13 am
Interesting way of doing it. Thanks.
Postby startz » Thu Jan 27, 2011 11:26 am
But there should be a way to do this. Wanting to show before vs after "event" data is pretty common.
javiersan
Postby javiersan » Fri Jan 28, 2011 8:19 am
I am almost sure that the following chart is not possible to do without manual fiddling of the date axis with addtext(s) (as I was doing with the chart types above before Gareth's stunned me with his super simple solution). It could be great if these types of double date axis charts were built into future Eviews versions.
Cheers,
Javier
Postby EViews Gareth » Fri Jan 28, 2011 9:02 am
Yeah, I can't think of another way to get that double scale. If we allowed carriage returns in obs labeling, it would be easy, but we don't :(
