Hi:
Is there a way to select a block of code and execute it? Currently I have to copy & paste each line individually to the Command window and press 'Enter' after each one. This is extremely inefficient. In MATLAB one can simply select code and press F9 and it executes. Does Eviews have an equivalent feature? If so, what is it?
Thank you.
Executing snippets of code quickly
Re: Executing snippets of code quickly
Paste them into a program instead of the command window?
CharlesLogan
True -- that's one way to do it, but not an ideal one. Having a quick way to execute a block of code (i.e. select the code and press one button) would enhance the Eviews experience tremendously.
