Open file on the web
javiersan
Postby javiersan » Thu Jan 13, 2011 6:58 am
The following is an example of a type of address on the web that I cannot figure out how to read in Eviews.
Say you want to wfopen the excel link provided in the page: http://www.bdl.gov.lb/edata/elements.as ... _BDLa_SID4
it's URL is http://www.bdl.gov.lb/edata/elementsXLS ... _BDLa_SID4
which when clicked opens a file called "BDLedata.xls"
but when you do
wfopen(t) "http://www.bdl.gov.lb/edata/elementsXLS.asp?Table=q_BDLa_SID4"
Eviews doesn't open any excel file.
Is there a solution to this problem?
Thanks,
Javier
Re: Open file on the web
Postby EViews Gareth » Thu Jan 13, 2011 9:00 am
Unfortunately EViews won't be able to interpret such a page. You'll have to download them manually :(
javiersan
Postby javiersan » Thu Jan 13, 2011 3:59 pm
Just to confirm, it isn't possible either to open the html page, isn't it?
This doesn't work:
wfopen(t=html) "http://www.bdl.gov.lb/edata/elements.asp?Table=q_BDLa_SID4"
Thanks,
Javier
Postby EViews Gareth » Thu Jan 13, 2011 4:03 pm
Correct. EViews cannot interpret ASP, which is the technology used to create that webpage.
