panel cointegration tests (Pedroni, Kao)
maragloria
Postby maragloria » Tue Jan 04, 2011 12:23 pm
Hi there,
I am trying to run two panel cointegration tests (Pedroni and Kao) using the following commands:
group beer reerln govexpratio nfanorm relprln totln 'Pedroni test beer.coint (pedroni,const, lag=a,info=sic) 'Kao test beer.coint (kao,const, lag=a,info=sic)
There are two problems:
1) The lag=a command is not being executed. On the results windows I get “ User-specified lag length: 1”
2) The Kao test command is not working. The command is actually executing the Pedroni test.
Thanks for your help,
Mara
Re: panel cointegration tests (Pedroni, Kao)
Postby EViews Gareth » Tue Jan 04, 2011 12:26 pm
Looks like you have a space between the command and the option parenthesis.
maragloria
Postby maragloria » Tue Jan 04, 2011 2:07 pm
You're totally right! Thanks so much.
