Just wondering if there is anyway I can estimate more than one equation in the estimate equation window please??
another question, when use BDS test, there are both BDS statistic and z-statistic, on what ground I should reject the null hypothesis of the BDS test?? what is v-statistic??
about estimate equation and BDS test
EViews Chris
Re: about estimate equation and BDS test
The z-statistic is the BDS-statistic divided by the standard error. It is the final result that is used for the hypothesis test (because it is asymptotically standard normal).another question, when use BDS test, there are both BDS statistic and z-statistic, on what ground I should reject the null hypothesis of the BDS test?? what is v-statistic??
EViews reports the probability that the given z-statistic would be observed from iid data in the Prob. column of the output, so you would reject the hypothesis that the series is iid if the reported probability is small.
The V-statistics are intermediate results used in calculating some of the other numbers. You can ignore them if you're only interested in the final results.
