Setobslabel/freeze does not work when plotting a matrix
maren
Postby maren » Wed Dec 29, 2010 3:24 am
Hello! I am having problems with getting setobslabel to work when in program mode.
When running the code below I get the error that "graph must be frozen...", but the graph IS frozen.
It works if I manually freeze an object and then execute the setobslabel command
(by clicking the mouse button on a freeze button).
Please advise,
Martin
(I am running Eviews 7.0, Jan 7 2010 build)
workfile y 2010 2010 matrix(5,2) TmpMtx TmpMtx.fill 1,2,3,4,5,6,7,8,9,10 freeze( mygraph ) TmpMtx.scat linefit mygraph.setelem symbol(dotobslabel) mygraph.setobslabel(1,2,current) "test"
trubador
Did you use forum search?
Re: Setobslabel/freeze does not work when plotting a matrix
Postby trubador » Wed Dec 29, 2010 5:09 am
Updating your copy of EViews will solve the problem:
http://eviews.com/download/download.html
maren
Postby maren » Thu Dec 30, 2010 12:07 am
Thanks trubador. I will try. I just wish I didn't have to engage in a battle with IT support every single time I needed something like this done :-)
