Simultaneous Equation with non-observable variable
Posted: Tue Dec 28, 2010 3:13 am
by ys1980
I have 2 independent variables (assume R1 R2, respectively) which are my sample data.
I want to estimate simultaneously 3 equations as follows (the 3th variable called R3 is non-observable):
Log(R3)=c(1)*R3(-1)+ c(2)*R3(-2)+ c(3)*R3(-3)
R1=c(4)*R3+c(5)*resid(-1)
R2=c(6)*R3+c(6)*resid(-1)
1.How can I run these equations at eviews?
2.How can I define the residual for each equation (in my question, there are to residual derive from each equation?
Re: Simultaneous Equation with non-observable variable
Posted: Tue Dec 28, 2010 6:56 am
by trubador
You can use "State Space Object". R1 and R2 are your signal variables, whereas R3 is your state variable. Please see the manual for details.
eq1.makeresids res1
eq2.makeresids res2
Posted: Tue Dec 28, 2010 7:26 am
by ys1980
can you please write me down the code for these equations?
where do I need to write it? should I need to create 3 equations?
Posted: Tue Dec 28, 2010 7:47 am
by startz
1. You should begin by taking a look at Chapter 33 of the online user's guide.
2. Are you sure you've read your homework assignment correctly? Those are odd looking equations unless there is more information that you've left out.
Posted: Tue Dec 28, 2010 8:09 am
by ys1980
this is a part of leading indicator model which is quite difficult to understand, it's not homework
Posted: Tue Dec 28, 2010 8:29 am
by startz
The model appears to not be identified, unless there are some further conditions. Suppose all R3 doubled and c(3) and c(4) were cut in half.
