Simultaneous Equation with non-observable variable
ys1980
Postby ys1980 » Tue Dec 28, 2010 3:13 am
I have 2 independent variables (assume R1 R2, respectively) which are my sample data.
I want to estimate simultaneously 3 equations as follows (the 3th variable called R3 is non-observable):
Log(R3)=c(1)*R3(-1)+ c(2)*R3(-2)+ c(3)*R3(-3)
R1=c(4)*R3+c(5)*resid(-1)
R2=c(6)*R3+c(6)*resid(-1)
1.How can I run these equations at eviews?
2.How can I define the residual for each equation (in my question, there are to residual derive from each equation?
trubador
Did you use forum search?
Re: Simultaneous Equation with non-observable variable
Postby trubador » Tue Dec 28, 2010 6:56 am
You can use "State Space Object". R1 and R2 are your signal variables, whereas R3 is your state variable. Please see the manual for details.
eq1.makeresids res1 eq2.makeresids res2
ys1980
Postby ys1980 » Tue Dec 28, 2010 7:26 am
can you please write me down the code for these equations?
where do I need to write it? should I need to create 3 equations?
Postby startz » Tue Dec 28, 2010 7:47 am
1. You should begin by taking a look at Chapter 33 of the online user's guide.
2. Are you sure you've read your homework assignment correctly? Those are odd looking equations unless there is more information that you've left out.
ys1980
Postby ys1980 » Tue Dec 28, 2010 8:09 am
this is a part of leading indicator model which is quite difficult to understand, it's not homework
Postby startz » Tue Dec 28, 2010 8:29 am
The model appears to not be identified, unless there are some further conditions. Suppose all R3 doubled and c(3) and c(4) were cut in half.
