Hello All
i've been trying to find a way that would allow a program i wrote (very large) to skip errors associated with fetching data. Because i'm writing a loop to fetch a large number of different series, a common problem i face is when a particular series doesn't exist.
i would like to code the program to skip errors and continue the fetching process
i've tried @isobject with no success (i think it works only for errors generated within a workfile)
many thanks in advance
Wes
Skip Errors when Fetching
Re: Skip Errors when Fetching
EViews 7 has a number of new tools for managing errors:
I suspect that clearerrs would work for you.
clearerrs
@errorcount
seterrcount
seterr
setmaxerrsRe: Skip Errors when Fetching
thank you Gareth
i'll look these up and see what i come up with
cheers
Wes
cheers
Wes
No problem!
Hey, wait a minute :)
Why don't you try something like:
%db="mydatabase::"
%ser_list="ser1 ser2 ser3"
%serfound=@wcross(%db,@wlookup(@wcross(%db,%ser_list)))
fetch {%serfound}
or something like that. The @wlookup will check whether the series exists in your database and return a string (without the mydatabase::).
Regards,
Javier
%db="mydatabase::"
fetch {%serfound}
Regards,
Javier
@Glenn ... sorry mate! Impuslive reaction i suppose ~ it's usually Gareth that I speak with
@Javier ~ thank you for the heads-up, I'll give it a try!
cheers all
Wes
cheers all
Wes
