restriction on coefficient for dummy variables in linear OLS
lmh
Postby lmh » Sun Dec 12, 2010 9:07 am
I am currently having issue in running a linear OLS by setting the restriction on the coefficient.
Appreciate if someone would be able to assist. I using E-view 7 at the moment.
Equation: y = c + B1X1 + B2X2 + B3X3+ B4X4 + B5X5 + e
X are dummy variable and B is the coefficient for X dummy variable respectively,
while e is error term.
My target is to run the above regression in programming by Restricting B1*W1 + B2*W2 + B3*W3 + B4*W4 +B5*W5 = 0.
#W refers to weight.
Appreciate if someone familiar with this offers some advices and guidance.
Thanks a million in advance.
Re: restriction on coefficient for dummy variables in linear OLS
Postby startz » Sun Dec 12, 2010 9:11 am
Solve the restriction to place B5, say, on the left. Then substitute in to the original equation, replacing B5 with your expression.
lmh
Postby lmh » Mon Jan 03, 2011 7:11 am
Thanks startz for your suggestion.
Just to confirm by doing so, i would lost the coefficient, B5 from the original equation as it has been substituted by the restricting equation. After the estimation, i would only obtain a constant, B1, B2, B3, B4 and an error term.
Is it possible that i could estimate the above equation and obtain the coefficients for all variables?
Thank you.
Postby EViews Gareth » Mon Jan 03, 2011 8:51 am
The point is that in your original equation you don't really have a B5. You've restricted it away.
