Question about "makeresids"
w_nawfal
Contact:
Postby w_nawfal » Thu Nov 25, 2010 4:20 pm
Hello All
both .makeresid or .makeresids work why? (the difference being the last letter "s")
also the (s) option seems to generate the same output as when i don't use it: as such how can i standardize the residuals?
lastly, given my equation is log(y) c x, its seems that when i want to work with the fitted values or residuals i don't have to take the exponential of these series, not sure why.
thank you so much for your help
Wes
Postby EViews Gareth » Thu Nov 25, 2010 5:38 pm
The two commands do the same thing, we support both in case people forget that last S.
As mentioned in the manual, the s option only applied to equations estimated by GARCH or limited dependent models.
EViews is smart enough to know you are probably interested in Y and not log(Y), so does the exponentialing for you
w_nawfal
Contact:
Re: Question about "makeresids"
Postby w_nawfal » Wed Dec 01, 2010 8:37 am
Thanks Gareth - that last point is especially useful!
cheers
Wes
