hello all
Does anyone know how to wrap text in a table cell? and merge two rows?
Wes
Wrap Text in Table Cells
Re: Wrap Text in Table Cells
Unfortunately neither are currently possible. You will need to use 2 rows. If needed, you can insert an empty row anywhere in the table (press the right mouse button while over a cell in the table and select 'Insert cells(s)'.
Additionally, you can also use the insertrow command. For example
mytable.insertrow(2) 3 'insert 3 blank rows starting at row #2Re: Wrap Text in Table Cells
thanks Jason ~ the documentation eluded to as much
but i was still hoping someone found a way around it :O)
cheers & thanks once more
Wes
Wes
Is this possible yet?
