Hallo,
I am wondering how to estimate a model using other methods then LS or TSLS (ML in my case) working with panel data - I tried to make a program but if I use the names of variables as I define them in the panel object for example cris_? or gdp_? then the Eviews does not recognize tham.... So probably I don't know the proper syntax..
I also guess it is possible to do that by making a system, but that does't seem userfriendly...
Thank you for any help....
Panel data programming
Re: Panel data programming
If you want to estimate an ML estimator, you have to use the LogL object to do it. Unfortunately you cannot mix a LogL object with a Pool object. Your best bet would be to create a panel workfile and use a LogL object in it, rather than using Pools (or Systems for that matter).
Thank you very much for quick reaction!
That could work....
That could work....
Dear QMS,
I d like to perform a probit estimation for a pool. Following your advice for others, I have created a panel wf for estimation. Now I try to program the execution but an error message pops up: binary is not a valid view for probit...etc. The command line for the equation is the following:
freeze(probit) probit.binary dum{%t} c dum{%v}{!k}{%lag}
As you see, I would like to collect the parameters/p-values in a table called probit. (I managed to program other parts of my research using pool estimation commands).
Do you have an equation called "probit" in your workfile already? If not, you'll need to declare it before doing that command.
Dear QMS Gareth! Thanks very much, I have renamed the equation in the wf from default to probit and worked!
All the best,
Vehicular
P.S. in pool mode i did not have to create an appropriately named equation in the wf before executing the program, or did i?
All the best,
Vehicular
