Extrapolation.
Re: Extrapolation.
Can you explain what you mean by Extrapolation?
Re: Extrapolation.
actually i have data from 1970 to 2008 but i want the values from 1960 . some one told me the Eviews can do this
Re: Extrapolation.
Without knowing which particular mathematical method you would like to use to estimate the values from 1960, it is hard to know whether EViews can do it or not.
Re: Extrapolation.
can you explain which methods are available
Re: Extrapolation.
That's a bit like asking how long is a piece of string. Linear extrapolation (i.e. just putting a straight line through the first two available points and extending that line back to 1960) is sort of built in.
Re: Extrapolation.
can you please check the attached excel file, what i have tried .
- extraploation mail.xlsx
- (16.38 KiB) Downloaded 850 times
Re: Extrapolation.
In order to extrapolate, you need some sort of model and it needs to rely on RHS data available during the early period. One such model is
Then use the forecast button and set the forecast smpl to be the early period. EViews will extrapolate backwards for you. Whether it's a good extrapolation depends on whether you've specified a good model.
ls y c @trendRe: Extrapolation.
We had the very same discussion before: viewtopic.php?f=18&t=3239
Re: Extrapolation.
Trubador,We had the very same discussion before: viewtopic.php?f=18&t=3239
While it's a little off-topic, how do you make one of those viewtopic link things?
Re: Extrapolation.
Hi Startz,
General approach is as follows:
When you click on the subject of a specific message or a topic, its address appears on the browser. For instance, your message's link is "http://forums.eviews.com/viewtopic.php? ... 282#p11081"
Then you can either do the following:
or simply copy and paste the link in the http format, which will produce the same thing as the former.
Code format is just for illustration purposes, since otherwise you would not be able to see the details. Hope it helps...
[url=Write the link here]And name it here[/url]Then you can either do the following:
[url=http://forums.eviews.com/viewtopic.php?f=4&t=3282#p11081]viewtopic.php?f=4&t=3282#p11081[/url]
[url=http://forums.eviews.com/viewtopic.php?f=4&t=3282#p11081]Your last message[/url]Code format is just for illustration purposes, since otherwise you would not be able to see the details. Hope it helps...
Re: Extrapolation.
http://forums.eviews.com/viewtopic.php?f=4&t=3282&view=unread#p11084
Thanks Trubador. I'll try to be better about using this.
Re: Extrapolation.
Actually our forum software does the trimming on internal post urls itself. Thus if you copy a full post url from the address bar and paste it into a post you're writing, without using the url tags, it will trim it for you:
