Regression Output (Graph)
w_nawfal
Contact:
Postby w_nawfal » Wed Oct 27, 2010 11:58 am
Hello All.
I'm using Eviews 7, which allows me to graphically present regression equations along with fitted values and a +/- standard deviation band etc. - but only when i select this option from the "view" menu on the equation out put.
what is the eviews code for this please?
Doc1.pdf
Print Screen of Eviews
(245.64 KiB) Downloaded 552 times
Re: Regression Output (Graph)
Postby EViews Gareth » Wed Oct 27, 2010 12:34 pm
If you're talking about View->Actual,Fitted,Residual->Actual,Fitted,Residual Graph, then the resids command will do it.
w_nawfal
Contact:
Postby w_nawfal » Wed Oct 27, 2010 2:15 pm
thanks a lot Gareth ~ that does the trick perfectly
(is there a way i can save this output as a graph in my workfile?)
Cheers
Wes
Postby EViews Gareth » Wed Oct 27, 2010 2:24 pm
use the freeze command.
rmoralesaramburu
Postby rmoralesaramburu » Mon Nov 18, 2013 9:15 am
I am having errors in this inquiry, I am using Eviews 8. If I run this code
t10ois.ls t10yr c ois_1yr2yr
t10ois.resid(g)
I am not getting the actual fitted, residual graph, instead I am getting this error
"T10ois is not defined in "DO_T10OIS.RESID(G)"
rmoralesaramburu
Postby rmoralesaramburu » Mon Nov 18, 2013 9:17 am
It is this code I am getting errors
t10ois.resids(g)
Postby EViews Gareth » Mon Nov 18, 2013 5:56 pm
Works for me:
create u 100 series t10yr = @nrnd series ois_1yr2yr = @nrnd equation t10ois t10ois.ls t10yr c ois_1yr2yr t10ois.resids(g)
rmoralesaramburu
Postby rmoralesaramburu » Tue Nov 19, 2013 6:47 am
Thanks!!
