Exporting table to Excel
VBoykis
Postby VBoykis » Thu Jan 08, 2009 9:07 am
Hi All,
I know there are ways to export series to Excel, but is there a command that allows for the export of tables to an Excel file, something along the lines of the write (t=xls) c:\documents\file.xls t_table
Thank you.
Re: Exporting table to Excel
Postby EViews Gareth » Thu Jan 08, 2009 9:25 am
EViews won't save a table directly to an Excel file, but it will save it as a CSV file (which Excel will open with no problems):
tablename.save(t=csv) c:\documents\file.csv
flash
Postby flash » Mon May 17, 2010 11:10 am
Hi all,
has any imporvement been made in eviews 7 in regards to the above issue or does this continue to be the case still ?
Thanks.
Postby EViews Gareth » Mon May 17, 2010 11:35 am
No change.
Karl1
Postby Karl1 » Tue Nov 19, 2013 6:30 am
The last line in the following commands did not work
modelbame.makegroup(s=m) table3b variablename1 variablename2
table3b.dtable
table3b.ddtabopts firstfreq(a) secfreq(none) display(year,7)
table3b.save(t=csv) c:\documents\table3b.csv
I get the error message "SAVE is not a valid view for TABLE3B in "DO_TABLE3B.SAVE(T=CSV) c:\documents\table3b.csv"."
Does anybody know what gets wrong here?
Postby EViews Gareth » Tue Nov 19, 2013 8:56 am
Your object, table3b, is not a table. It is a group. You'll need to freeze it into a table before saving.
Karl1
Postby Karl1 » Tue Nov 19, 2013 9:39 am
Seems like the freeze command freezes the raw data of the group, which is quaterly, and not the formated data, which is annual.
Is it possible to freeze the group as it is viewed?
Postby EViews Gareth » Tue Nov 19, 2013 9:40 am
table3b.ddtabopts firstfreq(a) secfreq(none) display(year,7) freeze(tab1) table3b.dtable
Karl1
Postby Karl1 » Wed Nov 20, 2013 1:56 am
Nice! Thanks!
nevernotnone
Postby nevernotnone » Wed Aug 10, 2016 8:00 am
Any update on this? I have a program that generates a number of summary tables that I would like to be able to write as multiple sheets within a single excel file.
Postby EViews Gareth » Wed Aug 10, 2016 8:50 am
No.
