Converting commands from GUI to command window
lpennington
Postby lpennington » Tue Oct 12, 2010 6:29 pm
I'm new to EViews, so please help. In other applications I have been able to use the windows GUI then switch to a command window and copy the programming lanuage which was created to achive the action. in other words, copy the macro and paste into a sub-routine. How does that work in EViews?
Thanks,
Lani
Re: Converting commands from GUI to command window
Postby EViews Gareth » Tue Oct 12, 2010 6:58 pm
In essence, it doesn't.
There are a few things where you can see the command that would have done the same thing. Equations, for example, have a Representations view from the View menu, which includes the command that was used to estimate them.
lpennington
Postby lpennington » Wed Oct 13, 2010 8:28 am
thanks
samijo
Postby samijo » Tue Jan 04, 2011 11:21 am
For a VAR of the variables X Y Z and 2 lags, the command reported in the representation window is
LS 1 2 X Y Z @ C
However, running it in the command window doesn't give the expected result.
Postby EViews Gareth » Tue Jan 04, 2011 11:39 am
why?
Postby EViews Gareth » Tue Jan 04, 2011 11:41 am
Ah, I guess you just put
LS 1 2 X Y Z @ C
rather than
VAR.LS 1 2 X Y Z @ C
Where VAR is the name of your VAR object.
