How to get the increase/decrease change of a variable?
meety99
Postby meety99 » Sun Oct 03, 2010 8:23 pm
Hi ,
My model is as below:
"Inflation Rate=" c "+ Output gap" +"Import price",
I am going to test whether the increase in output gap and the decrease in output gap have the symmetric effect on Inflation rate, so my model becomes two equation, I am going to put these two equation in an System:
delta (inflation rate)_"positive" =c +delta (output gap)_"positive"
delta (inflation rate)_"negative" =c +delta (output gap)_"negative"
But I don't know how to get the variable delta (inflation rate)_"positive"
from the the data of inflation rate? Could anyone give me some advice, thanks.
Re: How to get the increase/decrease change of a variable?
Postby startz » Sun Oct 03, 2010 9:23 pm
What precisely do you mean by delta (inflation rate)_"positive"?
trubador
Did you use forum search?
Postby trubador » Sun Oct 03, 2010 11:43 pm
I think your model is ill-defined, and the correct approach would be something to what Startz has suggested in your previous post. Regarding to your question, you can generate the series with the following expressions:
series inf_positive = (d(inflation_rate)>0)*d(inflation_rate)
or
series inf_positive = @recode(d(inflation_rate)>0,d(inflation_rate),0)
meety99
Postby meety99 » Mon Oct 04, 2010 6:22 pm
Thanks for your reply, sorry for the confusion, I am just wondering how get a series of "change value of the data", is it just d(inflation rate)?
meety99
Postby meety99 » Mon Oct 04, 2010 6:23 pm
or
Thanks a lot for your reply, it is helpful, I think I do have some problem with my model, I'd better define a reasonably model first:-)
Postby startz » Mon Oct 04, 2010 6:40 pm
That's right.
