Johansen Cointergration Test and Residuals
PERRYGOGAS
Postby PERRYGOGAS » Mon Sep 27, 2010 11:28 am
How can I obtain the residuals from the standard Johansen cointegration test?
I want to experiment with different lag lengths so that the residuals are normal and not serially correlated.
Re: Johansen Cointergration Test and Residuals
Postby EViews Gareth » Mon Sep 27, 2010 1:22 pm
You could make a VAR with the same co-integrating relationship as that given by the co-integration test. Then from the VAR you can make the residuals.
PERRYGOGAS
Postby PERRYGOGAS » Mon Sep 27, 2010 1:37 pm
Great! I was just trying to do this. Just to be 100% sure: the residuals I get from the VAR are the same as the Johansen cointegration residuals?
And something last: To get the residuals from the Johansen cointegration test including lags 1 to 3 for example, I must estimate the VAR with
1 to 4 lags and get those?
Thank you very much!!!
