Fixed Effects
nicojaq
Fixed Effects
Postby nicojaq » Tue Sep 07, 2010 2:16 am
Hi all,
I am using Eviews 7 and have an issue with a panel fixed-effect regression. I have used cross-section fixed effects since they seemed intuitive in my setting and the tests were highly significant. However, when I compute forecasts from this regression, for a few of my cross-sections (4 out of 20), the forecasts are computed without the fixed effects, resulting in the forecast showing an important bias against actual data. I don't understand why Eviews "ignores" these fixed effects (I've checked and they are non-zero) for these cross-sections.
Any help would be really appreciated.
Regards.
Fixed Effects
Postby EViews Gareth » Tue Sep 07, 2010 7:18 am
Could you post your workfile?
nicojaq
Re: Fixed Effects
Postby nicojaq » Wed Sep 08, 2010 1:30 am
Hi Gareth,
Here is the file. I recommend you look at eq1 on the panel_usd page of the workfile and at the graph_forecast and you'll see what I mean. At first I thought it was technical issue, but now I am wondering if it's not an econometric issue... am I pooling cross-sections that are too heterogeneous maybe?
Thanks for any opinion on the issue.
fair_value_fx._paneltestwf1.WF1
(510.77 KiB) Downloaded 228 times
Re: Fixed Effects
Postby EViews Gareth » Wed Sep 08, 2010 6:28 am
Which cross-sections do you believe are not using the fixed effects?
nicojaq
Re: Fixed Effects
Postby nicojaq » Wed Sep 08, 2010 9:18 am
I think in this setting THB, TWD, ZAR, PLN, RON, HUF, RUB and ILS don't use the fixed effects.
Re: Fixed Effects
Postby EViews Gareth » Wed Sep 08, 2010 9:30 am
I see what you mean. We'll investigate.
nicojaq
Re: Fixed Effects
Postby nicojaq » Tue Nov 23, 2010 10:22 am
Hi Gareth,
Did you find anything during your investigations?
Thanks.
Regards
Re: Fixed Effects
Postby EViews Gareth » Tue Nov 23, 2010 10:25 am
Yep, this issue was fixed in a patch a while back.
nicojaq
Re: Fixed Effects
Postby nicojaq » Fri Nov 26, 2010 2:57 am
a patch? sorry I don't understand.... what do I have to do? Thanks
Re: Fixed Effects
Postby startz » Fri Nov 26, 2010 8:54 am
Update your copy of EViews using the command on the Help menu.
nicojaq
Re: Fixed Effects
Postby nicojaq » Wed Oct 26, 2011 8:59 am
Hi Startz,
I have updated my version but I still get this issue. Any idea?
Thanks.
Re: Fixed Effects
Postby EViews Gareth » Wed Oct 26, 2011 9:01 am
If you click on Help->About EViews, what is the build date of your copy?
nicojaq
Re: Fixed Effects
Postby nicojaq » Wed Oct 26, 2011 9:10 am
May 122 2010. Does it mean it hasn't updated?
Re: Fixed Effects
Postby startz » Wed Oct 26, 2011 9:17 am
I believe the current version is October 14, 2011
Re: Fixed Effects
Postby EViews Gareth » Wed Oct 26, 2011 9:54 am
Download the upgrade installer:
http://eviews.com/download/download.html
